Assembly dili ödevi
vvolkannn
2 Haz 2020
Herkese Merhaba Hayırlı günler; Boyle bir ödevim var cok uğraştım ama yapamadım yardımcı olursanız makbule geçer.
Şimdiden teşekkürler
Eski dosyalardan şöyle birşey buldum belki bir fikir verir,inceleyin.
Epeydir asm de program yazmıyorum,inşallah faydası olur
LIST p=16F877
#include "P16F877.INC"
; Macro to generate a MOVLW instruction that also causes a model break:
break MACRO arg
DW 0x3100 | (arg & H'FF')
ENDM
cblock 0x20
count, lc1, lc2;
endc
; Vector for normal start up.
org 0
goto start
org 4
goto inthlr
; Main program starts here:
start clrw ; Clear W.
movwf PORTB ; Ensure PORTB is zero before we enable it.
movwf PORTD ; Ensure PORTD is zero before we enable it.
movwf count ; Reset count value.
movwf CCPR1H ; Clear.
movwf CCPR1L ; Clear.
; Set up ports:
bsf STATUS,RP0 ; Select Bank 1
movlw 0xFF ; Set W to mask for all inputs.
movwf TRISA ; set TRISA register as inputs.
movlw 0x00 ; Set W to mask for all inputs.
bcf STATUS,RP0 ; Select Bank 1
bsf PORTA,0
bcf PORTA,0
bsf PORTA,0
bcf PORTA,0
bsf STATUS,RP0 ; Select Bank 0
clrf TRISB ; Set TRISB register as outputs.
clrf TRISD ; Set TRISD register as outputs.
movlw 0x81 ; ADFM=1, all inputs analogue, +VREF enabled.
movwf ADCON1 ; Save it.
bcf STATUS,RP0 ; Select Bank 0.
movlw 0xC1 ; Clock/Channel select and enable.
movwf ADCON0 ; Save it.
movlw 0x01 ; Number of loops of 255 clocks.
call swait ; Wait for acquire time.
do_conv bsf ADCON0,GO
wait_eoc btfsc ADCON0,GO ; Is bit still set?
goto wait_eoc ; Yes, so loop and wait for end of conversion.
bcf STATUS,RP0 ; Ensure we have bank 0.
bsf PORTD,0 ; Show ISR in progress.
incf count,F ; Increment count.
; call disp_adc ; Display captured value.
bcf PORTD,0 ; Remove progress bit.
movlw 0x40 ; Count
movwf count ; Save it.
loop1 nop ; Dilly...
nop ; Dally...
nop ; Dilly...
decfsz count ; Decrement loop counter
goto loop1 ; Loop if no zero.
goto do_conv ; Do another conversion.
disp_adc bsf STATUS,RP0 ; Bank 1.
movf ADRESL,W ; Get ADRESL into W.
bcf STATUS,RP0 ; Bank 0.
movwf PORTB ; Write it to port
bsf PORTD,6 ; Toggle latch enable
nop ; Wait
nop ; Wait
bcf PORTD,6 ; Toggle latch enable
movf ADRESH,W ; Get ADRESH into W.
bsf PORTD,7 ; Toggle latch enable
nop ; Wait
nop ; Wait
bcf PORTD,7 ; Toggle latch enable
return
inthlr retfie
; Wait function
swait movwf lc2
_sw2 movlw 0xFF
movwf lc1
_sw3 nop
decfsz lc1,f
goto _sw3
decfsz lc2,f
goto _sw2
return
END
LIST p=16F877
break MACRO arg
ENDM
cblock 0x20
count, lc1, lc2;
endc
org 0
goto start
org 4
goto inthlr
; Set up ports:
bsf PORTA,0
bcf PORTA,0
bsf PORTA,0
bcf PORTA,0
movlw 0x40 ; Count
nop ; Dally...
nop ; Dilly...
nop ; Wait
nop ; Wait
nop ; Wait
nop ; Wait
return
inthlr retfie
; Wait function
swait movwf lc2
_sw2 movlw 0xFF
movwf lc1
_sw3 nop
decfsz lc1,f
goto _sw3
decfsz lc2,f
goto _sw2
return
END
Teşekkürler
Ali5534
