4 eksen kontrol kartı bağlantıları nasıl olacak
bu durumda ben buna 2 tane güç kaynağımı alacam ?
biri kart için 5 volt diğeri 542 için 24 volt çıkışlı
bu durumda buda çok ucuza gelmemiş oldu
5V için USB kullanabilirsin. Bunun için USB girişini koymuşlar...
kardeş
ayrıca bir kaç husus daha var anlamadığım
power input yazan yerde 16-32 v ve 12 v yazan yerler var oraya ne olacak
MACH3 CNC software for mainframe computers and peripheral power control signal transfer and processing.
Feature
1, all output and input models by Philips dedicated high-speed chip processing, the signal is an integer, amplification, eliminating unnecessary interference signal. The operation of the machine more stable.
2, USB and external power supply. The power supply isolation. Computer and data processing machines more secure
3, all of the input signal by the optical coupling isolation all of which P11, P12 port for high-speed optical coupling can be used to connect the spindle encoder, or hand-wheel A, B equal to demanding signal.
4, there is a special off the total electric power supply of the relay, the computer shuts down automatically when carving machine with other equipment, turn off all power.
5, there is a special relay switch coolant supply, support MACH3, G code programming (parallel port P3, G code to open M8, M9 off), the relay switch on the lights. Easy to determine thepower off.
6, there is a spindle-powered ad hoc relay support MACH3, G code programming (parallel port P2 I, G to open the code M3, M2 off), the relay switch on the lights. Easy to determine thepower-off
7, on the spindle speed control: special high-speed optical coupling isolation, can output PWM signal output for the parallel port P1.
8, the interface board have a PWM to 0-10V digital-analog conversion circuit. Can output 0-10V level to control the market and control the speed of only analog converter. To control the spindle speed. Output for the parallel port P1.
9, the interface board can be connected common cathode or common anode output to the stepper drive or servo drive. Output for the 5V level.
10, wide voltage power supply, 12V or 16-35V can choose a set of two power supply. Reversed with anti-power input design.
5 input port
Port description
P10 X limit
P11 on the knife
P12 emergency stop
P13 Y limit
P15 Z limit
11 output ports
Port description
P4 X pulse
P5 X direction
P6 Y Pulse
P7 Y direction
P8 Z pulse
P9 Z direction
P16 4 pulse
P17 4 Direction
P2 alternate port
P3 alternate port
P14 spare port
Package list:
  • 1 * interface board
  • 1*USB cable
12 V veya 16-35 V ile besleyebilirsiniz diyor. Alternatifli power girişi yapılmış.
(16-35 V dediği 16V ile 36V arasında herhangi bir voltaj)
hocam sıze msj attım gelmedı galıba
ismailgurel39
