16f877 LCD MENU SiSTEMi
biotec
7 Şub 2009
***************** 16F877 BİLGİLERİ *****************
@ DEVICE pic16F877
@ DEVICE pic16F877, WDT_on
@ DEVICE pic16F877, PWRT_off
@ DEVICE pic16F877, PROTECT_OFF
@ DEVICE pic16F877, HS_OSC
OPTION_REG.7=1 'PULL UP DİRENÇLERİNİN HEPSİ İPTAL
adcon1=7 'tum bacaklar dıgıtal ,ad converterler kapatılır
DEFINE OSC 4
'********** TÜRKÇE KARAKTERLİ SABİT YAZI **************'
LCDOUT $FE,$40,$0A,$00,$11,$11,$11,$11,$0E,$00 'Ü = 0
LCDOUT $FE,$48,$0E,$11,$10,$10,$11,$0E,$04,$00 'Ç = 1
LCDOUT $FE,$50,$04,$00,$0E,$04,$04,$04,$0E,$00 'I = 2
LCDOUT $FE,$58,$0A,$00,$0E,$11,$11,$11,$0E,$00 'Ö = 3
LCDOUT $FE,$60,$0E,$00,$0F,$10,$13,$11,$0F,$00 'Ğ = 4
LCDOUT $FE,$68,$0E,$11,$10,$0E,$01,$15,$0E,$04 'Ş = 5
'***************** LCD TANIMLAMALARI ******************'
DEFINE LCD_DREG PORTD 'LCD DATA BACAKLARI PORTB'YE BAĞLI
DEFINE LCD_DBIT 4 'LCD DATA BACAKLARI PORTB.4 BAĞLI
DEFINE LCD_EREG PORTD 'LCD ENABLE PİNİ PORTB'YE BAĞLI
DEFINE LCD_EBIT 3 'LCD ENABLE PİNİ PORTB.3 BAĞLI
DEFINE LCD_RSREG PORTD 'LCD RS PİNİ PORTB'YE BAĞLI
DEFINE LCD_RSBIT 2 'LCD RS PİNİ PORTB.2 BAĞLI
DEFINE LCD_BITS 4 'LCD 4 BIT BAĞLI
DEFINE LCD_LINES 4 'LCD 4*20
'************ GİRİŞ VE ÇIKIŞLARI TANIT *********************
TRISA=%011111
TRISB=0
TRISC=0
TRISD=0
TRISE=0
PORTB=0
PORTC=0
PORTD=0
PORTE=0
'***************** MENÜ BUTONLARI *********************
SYMBOL YUKARI=PORTA.0
SYMBOL ASAGI=PORTA.1
SYMBOL GIR=PORTA.2
SYMBOL CIK=PORTA.3
SYMBOL MENU=PORTA.4
ANA VAR BYTE
MAKINA_1 VAR BYTE
'************** BİLGİLERİ TEMİZLEME İŞLEMİ *************
LCDOUT $FE,1 'LCD EKRANI TEMİZLE
pause 500 'LCD HAZIRLANIYOR
ANA = 0
MAKINA_1 = 0
CLEAR 'BÜTÜN DEĞİŞKENLERİ SIFIRLA
'************* PROGRAM BAŞLANGICI ******************
BASLA:
IF ANA = 0 AND MENU = 0 THEN
PAUSE 200
ANA = 1
WHILE menu = 0
wend
ENDIF
IF ASAGI = 0 THEN
ANA = ANA + 1
PAUSE 200
WHILE ASAGI = 0
wend
ENDIF
IF YUKARI = 0 THEN
ANA = ANA - 1
PAUSE 200
WHILE YUKARI = 0
wend
ENDIF
IF ANA > 5 THEN
ANA = 1
PAUSE 200
ENDIF
'***************************** LCD ANA DİZİNLER *******************************
ANA_EKRAN:
select case ANA
case 1:
lcdout $FE, $2, "MEN",0," S",2,"STEM",2," :",#ANA
lcdout $FE, $C0, "*1. MAKINA "
lcdout $FE, $94, " 2. MAKINA "
lcdout $FE, $D4, " 3. MAKINA "
case 2:
lcdout $FE, $C0, " 1. MAKINA "
lcdout $FE, $94, "*2. MAKINA "
case 3:
lcdout $FE, $C0, " 2. MAKINA "
lcdout $FE, $94, "*3. MAKINA "
lcdout $FE, $D4, " 4. MAKINA "
case 4:
lcdout $FE, $C0, " 3. MAKINA "
lcdout $FE, $94, "*4. MAKINA "
lcdout $FE, $D4, " 5. MAKINA "
case 5:
lcdout $FE, $C0, " 5. MAKINA "
lcdout $FE, $94, "*6. ",1,"IKI",5," "
lcdout $FE, $D4, " 1. MAKINA "
end select
'**************************** LCD 1. MAKİNA DİZİNLER **************************
MAKINA_1_EKRANI:
select case MAKINA_1
case 1:
lcdout $FE, $2, "1. MAKiNA MEN",0,"S",0,":",#MAKINA_1
lcdout $FE, $C0, "*1. G",2,"R",2,5
lcdout $FE, $94, " 2. G",2,"R",2,5
lcdout $FE, $D4, " 3. ",1,"IKI",5," "
case 2:
lcdout $FE, $C0, " 1. G",2,"R",2,5
lcdout $FE, $94, "*2. G",2,"R",2,5
case 3:
lcdout $FE, $C0, " 2. G",2,"R",2,5
lcdout $FE, $94, "*3. ",1,"IKI",5," "
lcdout $FE, $D4, " 1. G",2,"R",2,5
end select
GOTO BASLA
end
çizimler:
Dosyalar, Dosya Paylaşım Sitesinden Silindiği İçin Bu Konu Çöpe Taşınmıştır.
hocam bu hangi dilde yazılmıştır???
hocam asm ye yenı basladım bunun asm ve hex dosyalarını cevirip paylaşırmısınız. bilen arkadaslardan rıca edıyorum. proje odevı olarak sunacagım
resim yerine dsn dosyası yüklemek daha iy olmazmıydı
bu kadar yazılımı aklında tutan varmı ccs yazılımı yaparak ...
S.A.
Sn. Uğur proton kullanıyorum bunun benzeri uygulamaları kullanıyorum ama biraz daha güzel ve kullanışlı Tabiki komutların çoğu programlarda aynı. Bu programı ccs c uyarlayabilirsin. Kolay gelsin.
S.A.
CCS ile yaptığım bir ödev projesi. Uğur Keklik istemişti ama o zaman CCS e başlamamıştım
ESENBEL
