ccsc ile yazılmış pıc'li voltmetre
xman
9 Eki 2008
merhaba devreyle baya bi uğraştım çalıştıramadım yada bilgilerim yetersiz geliyo desem daha doğru olcak derlerken problem yok diyo ama simulasyonda çalıştırmıyo . simulasyon çizimi yazılım hepsi rar içinde
teşekkürler.
Kod:
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
#use delay (clock=4000000) // 4MHz clock
#rom  0x3ff={0x3444}
#byte PORTA = 0x05
#byte PORTC = 0x07
#byte TRISA = 0x85
#byte TRISC = 0x87
#define SPORTA PORTA
#define SPORTC PORTC
#define  TICKS_BETWEEN_INTERRUPTS      5000 //5000
#define  INTERRUPT_OVERHEAD            35
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};
   //                       0    1    2    3    4    5    6    7    8    9
const char Column[3]   = {0x02,0x01,0x04};
static char Segment[3] = {0x7f,0x7f,0x7f};
static unsigned char ColCount=0x00;
void CPU_SETUP(void);
void Display(void);
void HTO7S(unsigned int32 Num);
byte i;
unsigned int32 result;
#INT_TIMER1
void Timer1(void)
   set_timer1(TMR1RESET);
   Display();
void main()
   unsigned char i;
   CPU_SETUP();
   while(true)
      result=0;
      for (i=0;i<20;i++)
         set_adc_channel(3);
         delay_ms(1);
         result=result+read_adc();
        //result = 0x3fe;
       HTO7S(result/20);
      delay_ms(200);
void CPU_SETUP()
   setup_comparator(NC_NC_NC_NC);   // not use comparator module
   setup_adc_ports( sAN3 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   TRISA=0b00011000;
   PORTA=0x27;
   TRISC=0b00000000;
   PORTC=0x37;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_TIMER1);
// Display routine
void Display()
   PORTA = 0b00100111;     // off all digits column and Segment G
   PORTC = 0b00111111;   // off segment a-f
   delay_cycles(2);
   if (ColCount>=3)
   ColCount=0;
   SPORTC = Segment[ColCount];
   SPORTA = ((Segment[ColCount] & 0b01000000)>>1) | (Column[ColCount]^0x07);
   ColCount++;
// Convet HEX 2 byte to 7-Segment code
   unsigned int32 res;
   Segment[0]=SegCode[30*Num/10230];
   if (Segment[0]==0x40)
   Segment[0]=0xFF;
   res = 30*Num%10230;
   Segment[1]=SegCode[10*res/10230];
   res=10*res%10230;
   Segment[2]=SegCode[10*res/10230];
ek olarak bu devreyi güç kaynağına bağlasam iş görürmü 60w 0-24v 5A voltmetreyi beslemeyi trafo kademeli olduğu için 12v luk gerilimi 7805li bi doğrultmaçla yapmayı planlıyorum teşekkürler.
halefly
