Timer1 kesmesi ile duraklat ve devam ettir yapılabilirmi?
kumandan11
4 Ağu 2013
Aşağıdaki kodda durdurma işlemi yapabiliyorum. Duraklat ve Devam ettir işleme eklemek istiyorum. Nasıl yapabilirim?
C:
  pump
uint8_t pump(int8_t pumpingDirection, uint32_t flowrate, uint32_t volume)
  float tempFloat;
  ustepCounterLimit = (uint32_t)(coef * volume + 0.5);
  ustepCounterLimit *= NOFMICROSTEPS;
  float ustepsPERmin = coef * NOFMICROSTEPS * (float)flowrate;
  if (ustepsPERmin < 14.4) ustepsPERmin = 14.4;
  float multiplier;
  if (ustepsPERmin >= 229) multiplier = 15000000;
  else multiplier = 937500;
  tempFloat = multiplier / ustepsPERmin;
  uint16_t countsPERustepActual = (uint16_t)(tempFloat + 0.5);
  float ustepsPERsActual = multiplier / (float)countsPERustepActual;
  ustepsPERsActual /= 60;
  lcd.clear();
  lcd.setCursor(0, 0);
  if (pumpingDirection > 0)
    endStopPin = ENDSTOP_PIN1;
    if (INVERTDIRECTION == true) digitalWrite(DIRECTION_PIN, LOW);
    else digitalWrite(DIRECTION_PIN, HIGH);
    lcd.print(F(">> DOLDURULUYOR >>"));
  else
    endStopPin = ENDSTOP_PIN2;
    if (INVERTDIRECTION == true) digitalWrite(DIRECTION_PIN, HIGH);
    else digitalWrite(DIRECTION_PIN, LOW);
    lcd.print(F("<< BOŞALTILIYOR <<"));
  lcd.setCursor(0, 1);
  printTimeAndVolume(0, 0);
  TCNT1 = 0;
  TCCR1A = 0;
  TCCR1B |= (1 << WGM12);
    TCCR1B &= ~( 1 << CS12);
    TCCR1B |= (1 << CS11);
    TCCR1B |= (1 << CS10);
  else
    TCCR1B |= (1 << CS12);
    TCCR1B &= ~( 1 << CS11);
  digitalWrite(ENABLE_PIN, LOW);
  digitalWrite(STEP_PIN, LOW);
  ustepCounter = 1;
  uint32_t ustepCounterActual;
  float coef2 = ((float)items[LINK2LPV].value * stepsPERmm * 1e-9) * (float)valueDivider(VOLUME) * NOFMICROSTEPS * 10;
  bool isManualStop = false;
  uint32_t pumpingVolume;
  uint16_t pumpingTime = 1;
  uint32_t nextMillis = millis() + 1000;
  OCR1A = (countsPERustepActual - 1);
  TIMSK1 |= (1 << OCIE1A);
  while ( (TIMSK1 & (1 << OCIE1A)) )
    button = NA;
    getButtonState();
    if (buttonState == SHORTPRESS && lastButton == LEFT)
      buttonState = MEDIUMPRESS;
      lcd.print(F(" POMPA DURDUR?  "));
      lcd.print(F("(EVET)   (HAYIR)"));
        button = NA;
        getButtonState();
        if (buttonState == SHORTPRESS)
          if (lastButton == LEFT)
            TIMSK1 &= ~( 1 << OCIE1A);
            isManualStop = true;
          else if (lastButton == RIGHT)
            if (pumpingDirection > 0) lcd.print(F(" >> DOLDURULUYOR >> "));
            else lcd.print(F("<< BOŞALTILIYOR <<"));
            break;
    if (nextMillis <= millis())
      cli();
      ustepCounterActual = ustepCounter;
      sei();
      pumpingVolume = (uint32_t)(((float)ustepCounterActual / coef2) + 0.5);
      printTimeAndVolume(pumpingTime, pumpingVolume);
      pumpingTime++;
      nextMillis += 1000;
  digitalWrite(ENABLE_PIN, HIGH);
  button = NA;
  pumpingVolume = (uint32_t)(((float)ustepCounter / coef2) + 0.5);
  if (isManualStop)
    lcd.print(F("MANUEL DURDURMA "));
    button = NA;
    return 2;
  if (ustepCounterLimit == ustepCounter - 1)
    lcd.print(F("     BİTTİ      "));
    button = NA;
    return 0;
  else
    lcd.print(F("  HATALI DURUŞ  "));
    button = NA;
    return 1;
  ISR(TIMER1_COMPA_vect)
  digitalWrite(STEP_PIN, HIGH);
  if (ustepCounter == ustepCounterLimit) TIMSK1 &= ~( 1 << OCIE1A);
  if ( digitalRead(endStopPin) == LOW) TIMSK1 &= ~( 1 << OCIE1A);
  delayMicroseconds(10);
  ustepCounter++;
Timer1 kütüphanesindeki:
TCNT1= 0 satrını TCNT1=1 yaparak deneneyin
Timer kesmesi kullanarak yapılan işlemlerde Timer kesmesini kapatıp açmak bazı durumlarda sorun yaratabilir. Onun yerine isr içine bir kontrol değişkeni koyup onun durumuna göre isr deki kodları çalıştırarak işlemleri yaptırabilirsin. Eğer çok acil bir durdurma gerekiyorsa başlatma ve durdurma butonlarını yine pin durumuna göre kesme yapabilen pinlere bağlamak daha kararlı bir sonuç oluşturacaktır.
Aşağıda basit bir örnek var.
volatile boolean motor_durdur_baslat=false;
eğer durdur butonuna basılmışsa
motor_durdur_baslat =false;
eğer başlat yada devam ettir butonuna basılmışsa
motor_durdur_baslat =true;
if( motor_durdur_baslat == false )
return ;
ustepCounter++;
Ayrıca (MCU) Micro controller Unit 'ler ile çalışıyorsan " state machine programming " öğrenmen çok iyi olacaktır.
riki35
