Hırçın 41
Profesyonel Üye
- 17 Ara 2013
- 4,740
- 2,554
Step 1: What You Will Need:
Parts/ Materials:
- 64 Diffused LEDs $2.00
- 4 100 OHM Resistors $1.00
- Pin Header $0.50
- Slide Switch $1.00
- Wire $0.75
- Craft Wire $0.25
- Perf Board $2.00
- Project Box $6.00
- 9V Power Supply $1.00
Tools/ Adhesives:
- Arduino Uno
- Drill
- 1/16" Drill Bit
- 5/16" Drill Bit
- Knife
- Straight Edge
- Needle Nose Pliers
- Soldering Iron
- Solder
- Hot Glue Gun
First, Start by printing out my 4x4x4 LED Cube Template and paste it to a cardboard box.Make sure that the printing settings are set to actual size and landscape orientation. Next, punch out all 16 LED holes(grey dashed circles) using a pencil. Insert a LED into the individual holes to test the fit.
http://www.instructables.com/id/4x4x4-LED-Cube-Arduino-Uno/?ALLSTEPS
Saygılar
