Arçelik 72 ekran 50 hz geometri ayarları lazım yardım !!
alex21
27 Ocak 2012
72 ekran 7472 model 50hz orjinal geometri ayarını bilen varsa yardımcı olsun teşekkürler..
BEKO 70 ekran servis değerleri
1)options
standby :customer mode
av1 yuv :n/a
av2 & av3 :av2 avail.-av3 n/a
av4 :cvbs+svhs
teletext :fastext
txttable :auto
language :1
crt :4:3
pip :n/a
main tuner :pan.db2g3-da5g
pip tuner :philips
svm &dci :eek:ff
blueback :eek:ff
lti &comb :eek:ff
cti :eek:ff
dynamic focus :eek:ff
protection :n/a
panorama :n/a
***board :p- p+ v- v+
calculator :n/a
game :n/a
alarm timer :n/a
demo mode : 0
2)sound options
bg :europe
dk :n/a
i :n/a
l/l’ :n/a
fm radio/tv guide :none
nicam :n/a
dolby virtual :n/a
bass option :none
headphone :n/a
carrİer mute :via micro
pat :n/a
simple hotel :n/a
hotel max vol. : 31
osd offset :1020
bcl delta : 50
agc method :sync+peak white
tilt :n/a
tilt 0 : 32
crt 4:3 mode 16:9 :via flybl
adaptive pkg :eek:n
3)if adj.
Agc : 4
agc for vhf 1 : 4
pip agc : 15
pip agc for vhf 1 :20
4)50 hz geom.
Vertical amplitude : - 41
vertical shift : -2
horzontal width : +50
horzontal shift : -44
trapeze corr. I : -26
cushion corr. I : -160
upper corner 1 i : +40
lower corner 1 i :+40
upper corner 2 i : -3
lower corner 2 i : +5
linarty : 0
s-correction : +160
vertical angle : +2
vertical bow : 0
start line measur : 11
ver. Blanking stop : 20
hor. Blanking stop : 200
hor. Blanking start : 1220
hor.osd position : 31
ver. Osd position : 19
5)50 hz. Geom hor ii
hor width ii : 0
ver.zoom ii : 60
flybl : 14
trapeze corr ii : -53
cushion corr ii : -120
upper corner 1 ii : 0
lower corner 1 ii : +20
upper corner 2 ii : -11
lower corner 2 ii : +28
6)50 hz. Gem eht
eht treshold : 55
eht time constant : 40
vertical eht 1 : -105
vertical eht 2 : 0
horzontal eht 1 : -170
horzontal eht 2 : -20
eht dtc : -10
eht p 1 : -50
eht p 2 : -40
7)60 hz geom
vertical amplitude : -40
vertical shift : +2
horzontal shift : -61
trapeze corr i : -40
cushion corr i : -155
upper corner 1 i : -44
lower corner 1 i : +61
upper corner 2 i : +59
lower corner 2 i : -12
linearty : -5
s-correction : +160
vertical angle : +4
vertical bow : +2
ver. Blanking stop : 17
ver. Blanking start : 333
hor. Osd position : 16
ver. Osd position : 11
8)60 hz geom hor ii
hor. Width ii : 0
ver. Zoom ii : 60
custoff timer : 10
trapeze corr ii : -26
cushion corr ii : -130
upper corner 1 ii : -18
lower corner 1 ii : -3
upper corner 2 ii : 0
lower corner 2 ii : 0
9)60 hz gem eht
eht treshold : 45
vertical eht 1 : -130
vertical eht 2 : 0
horzontal eht 1 : -230
horzontal eht 2 : -30
eht dtc : -50
eht p 1 : -40 eht p 2 : -34
  • video adj. I
r. Drive : 426 ….
G. Drive : 356 ….
B. Drive : 366 ….
R. Cutoff : 206 ….
G. Cutoff : 156 …
b. Cutoff : 156 …..
Ibrm : 330
wdrm : 310
screen adj. : 190
  • video adj ii
bcl gain : 250
bcl treshold : +240
bcl treshold ii : +220
bcl time constant 1 : 511
bcl time constant 2 : 0
osd brightness : 100
osd contrast : 200
txt brightness : 120
txt contrast : 170
yc delay for pal : 9
yc delay for secam : 2
yc delay for ntsc : 10
subcarrier adj. : 18
  • video adj. Iii
dpwl gain : -300
dpwl start p. : 520
pwl time constant : 1
pwl : 250
swm gain : 30
swm coring : 7
swm limiter : 63
swm delay : 3
swm diff. Window : 4
  • pip position
  • eeprom edit
address : ---h
data(hex) : 00h
data(binary) : 0000 0000b
birader 72ekranla uyumlu mudur ama sağol deneyecem..
olmadı bu değerler.. konu günceldir
mrtblkl
