Quartz lamba kontrolü
secure
19 Nis 2014
Merhaba..
Quartz lambalar SSR ile kontrol edilebilir mi?
Isı kontrollü küçük bir fırın yapmak istiyorum kendime
Bir yerde okudum SSR değilde SCR diye rölelerle kontrol ediliyormuş doğru mu bilmiyorum.
https://www.omron-ap.com/service_support/FAQ/FAQ02243/index.asp
Silicon Controlled Rectifier (SCR)
This electronically controlled relay is available for single phase and 3-phase, zero cross firing and phase angle firing. A phase angle fired SCR can switch power in less than 10 millisecond. A phase angle fired SCR "must" be used for infrared heating applications (examples: furnaces, quartz infrared heaters, T3 lamps) and is also commonly used in the solar industry and heat treatment applications. We recommand to use a zero cross power controller for industrial air heating applications. see also FAQ about SCR power controller.
Kaynak
https://www.deltat.com/switching_power.html
SCR "must" be used dediği için sormak istedim belki quartz lambalar sürekli kapa aç'a uygun değildir diye
g-silver
