Klavyeah
- 28 Ağu 2006
- 274
- 3
- Yaş
- 36
Elektrik Animasyonları Hemde Yüzlerce
Not: Bu Animasyonlar Eğitim Amaçlıdır Faydalı Olacağına inaniyorum
Animasyon Serisi 8 güncelleme 19 nisan 2008
Kod:
e_devresi1.swf
e-devresi2.swf
e-devresi3.swf
Electric20.swf
electric21.swf
elektrik1.swf
elektrik2.swf
elektrik3.swf
elektrik4.swf
elektrik5.swf
elektrik7.swf
elektrik9.swf
elektrik10.swf
elektrik11.swf
elektrik12.swf
elektrik13.swf
elektrik14.swf
elektrik15.swf
elektrik16.swf
elektrik17.swf
elektrik18.swf
elektrik19.swf
elektrik_akimi.swf
elektrik_nakli.swf
elektrik_uretimi.swf
elektriksel_guc.swf
enerji_nakli.swf
3 Fazlı Asm.swf
ac_akimi.swf
ac_resistor2.swf
acmotor.swf
akım.swf
Asenkron Motorlar.swf
batarya.swf
batterie1.swf
batterie2.swf
batteries.swf
buhar.swf
buhar_makinesi3.swf
buharmakinesi1.swf
cam_silecegi.swf
cap1.swf
cap2.swf
capacitor.swf
capacitor_charging.swf
coal.swf
Dc Motor2.swf
Dc Motor.swf
dc_akimi.swf
dc-gen.swf
DCMotor1.swf
DCMotor2.swf
DCMotor7.swf
DCMotor8.swf
DCMotor.swf
dc-motor.swf
Devre1.swf
Devre2.swf
Devre3.swf
Devre4.swf
Devre5.swf
Devre6.swf
Dirençlerin Karışık Bağlanması.swf
disli_pompa.swf
drehpul.swf
entladen.swf
Filtreli Doğrultmac.swf
flasher.swf
galvan.swf
Gazturbini.swf
gosterge1.swf
gosterge2.swf
gosterge.swf
hidrolik Enerji.swf
hidrolik_pompa.swf
hidrolikpompa.swf
Hoparlor.swf
hydroelectric.swf
ind1.swf
ind2.swf
karisik_devre.swf
karisik-Devre2.swf
kimyasal.swf
lcd-matrix.swf
led-photon.swf
ledpolarity.swf
Lenz Kanunu.swf
loopanalysis.swf
machenregel.swf
magnet1.swf
miknatis1.swf
miknatis2.swf
miknatis3.swf
miknatis4.swf
miknatis5.swf
miknatis6.swf
miknatis7.swf
miknatis8.swf
miknatis9.swf
miknatis10.swf
Kirsof Akımlar Kanunu.swf
Kirsof gerilim Kanunu.swf
klima1.swf
klima2.swf
klima3.swf
klima4.swf
klima11.swf
klima22.swf
klima.swf
knotenregel.swf
laden.swf
movie-sound-animation2.swf
nodalanalysis.swf
nuclear-power-reactor.swf
nuclear-power-reactor[1].swf
NukleerGucReaktoru.swf
ohm.swf
ohm-kan.swf
opamp.swf
opampfancontrollerfet.swf
operating-system-memory.swf
oscope2.swf
oszilloskop1.swf
otoklav.swf
PAketleme Sistemi.swf
parallel.swf
parallel_devre1.swf
parallel_devre2.swf
parksensoru1.swf
parksensoru2.swf
pres2.swf
miknatis11.swf
miknatis12.swf
mikrometer.swf
motor11.swf
motor.swf
motorAC.swf
motorDC.swf
Motorlar tümü.swf
resonance2.swf
rotary-engine-animation.swf
router-lan.swf
santifrujpompa.swf
sch-laeu.swf
select.swf
seri_devre1.swf
serie.swf
servo.swf
sewing-machine-lock.swf
Sinyal1.swf
sinyal2.swf
skineffect.swf
speaker-diagram.swf
speakerforpower.swf
speaker-sound.swf
speakervaryingvoltage.swf
speakervoicecoil.swf
pulsewidthdemo.swf
radar2.swf
RADAR.SWF
radar-detector-doppler.swf
rc_circuits2.swf
rectificationandfilteringtopdiagram.swf
relay.swf
relaycoilvoltagedemo.swf
resistance_parallel.swf
resistance_series.swf
transistorexample2.swf
turbine_a.swf
turn-signal-thermal-flasher.swf
universalmotor.swf
vinc1.swf
vinc2.swf
vinc3.swf
WaterAnalogy.swf
yakitgostergesi.swf
speaker-working.swf
stepper.swf
superposition.swf
switchrocker.swf
switchstructure.swf
swrelayflashdemo2.swf
swrelayflashdemo.swf
swreluct.swf
telephon.swf
telephone-network.swf
transform1.swf
transform2.swf
transformator.swf
akim_gecis_metal.swf
alternator2.swf
dinamo.swf
iletkeninHareketi.swf
akimmetal.swf
alternator.swf
dinamo1.swf
hareketAlan.swf
motor.swf
