public abstract class ModbusBaseClientStation
protected string name;
protected Plugin plugin;
protected int cycleTimeout;
protected int retryTimeout;
protected int retryCount;
protected int failedCount;
protected List<ModbusChannelImp> channels = new List<ModbusChannelImp>();
protected List<ModbusBuffer> buffers = new List<ModbusBuffer>();
protected Dictionary<byte, ModbusChannelImp> failures = new Dictionary<byte, ModbusChannelImp>();
protected Queue<ModbusChannelImp> sendQueue = new Queue<ModbusChannelImp>();
protected object sendQueueSyncRoot = new object();
protected ManualResetEvent sendQueueEndWaitEvent = new ManualResetEvent(false);
protected List<ModbusChannelImp> channelsToSend = new List<ModbusChannelImp>();
protected volatile bool runThread;
public ModbusBaseClientStation(string name, Plugin plugin, int cycleTimeout, int retryTimeout, int retryCount, int failedCount)
this.name = name;
this.plugin = plugin;
this.cycleTimeout = Math.Max(cycleTimeout, 10);
this.retryTimeout = Math.Max(retryTimeout, 100);
this.retryCount = Math.Max(retryCount, 1);
this.failedCount = Math.Max(failedCount, 1);
this.LoggingLevel = 0;
this.StationActive = true;
public string Name
get { return name; }
set { name = value; }
public int CycleTimeout
get { return cycleTimeout; }
set { cycleTimeout = value; }
public int RetryTimeout
get { return retryTimeout; }
set { retryTimeout = value; }
public int RetryCount
get { return retryCount; }
set { retryCount = value; }
public int FailedCount
get { return failedCount; }
set { failedCount = value; }
public int LoggingLevel
get;
set;
public bool StationActive
get;
set;
public void AddChannel(ModbusChannelImp channel)
channels.Add(channel);
public void ClearChannels()
channels.Clear();
public void SendValueUpdateToModbusLine(ModbusChannelImp ch)
if (runThread)
lock (sendQueueSyncRoot)
sendQueue.Enqueue(ch);
sendQueueEndWaitEvent.Set();
public bool Running { get { return runThread; } }
public void Stop()
//MessageBox.Show("Stopping Modbus station " + name, "Info");
if (!StationActive) return;
runThread = false;
sendQueue.Clear();
public int Start()
//MessageBox.Show("Starting Modbus station " + name, "Info");
if (!StationActive) return 1;
buffers.Clear();
failures.Clear();
sendQueue.Clear();
if (channels.Count > 0)
//// Data Space analyse
channels.Sort(channels[0].Compare);
foreach (ModbusChannelImp ch in channels)
if (ch.ModbusReadWrite != ModbusReadWrite.WriteOnly && ch.ModbusDataType != ModbusDataTypeEx.DeviceFailureInfo)
bool found = false;
foreach (ModbusBuffer buf in buffers)
if (ch.SlaveId == buf.slaveId && ch.ModbusDataType == buf.ModbusDataType)
int mult;
if (ch.ModbusDataType == ModbusDataTypeEx.Input || ch.ModbusDataType == ModbusDataTypeEx.Coil)
mult = 16;
else
mult = 1;
if (((ch.ModbusDataAddress - buf.lastAddress) < 4 * mult) && ((buf.lastAddress - buf.startAddress + ch.DeviceDataLen) < 120 * mult))
// Optimization - "holes" in address space less than 4 words
// will be included in one read until max frame 2*120 bytes is reached
buf.lastAddress = (ushort)((ch.ModbusDataAddress + ch.DeviceDataLen - 1) > buf.lastAddress ? ch.ModbusDataAddress + ch.DeviceDataLen - 1 : buf.lastAddress);
buf.numInputs = (ushort)((buf.lastAddress - buf.startAddress + ch.DeviceDataLen) > buf.numInputs ? buf.lastAddress - buf.startAddress + ch.DeviceDataLen : buf.numInputs);
buf.channels.Add(ch); ch.StatusFlags = ChannelStatusFlags.Bad;
found = true;
if (!found)
// Set up a new buffer
ModbusBuffer buf = new ModbusBuffer();
buf.slaveId = ch.SlaveId;
buf.numInputs = ch.DeviceDataLen;
buf.startAddress = ch.ModbusDataAddress;
buf.lastAddress = (ushort)(ch.ModbusDataAddress + ch.DeviceDataLen - 1);
buf.ModbusDataType = ch.ModbusDataType;
buf.pauseCounter = 0;
buffers.Add(buf);
if (ch.ModbusDataType == ModbusDataTypeEx.DeviceFailureInfo)
if (failures.ContainsKey(ch.SlaveId))
// failure signal already defined, parameterization error
if (LoggingLevel >= ModbusLog.logErrors)
Env.Current.Logger.LogError(string.Format(StringConstants.ErrFailureTwice, this.Name, failures[ch.SlaveId].Name, ch.Name));
else
failures.Add(ch.SlaveId, ch);
ch.Value = true;
return 0;
return 1;
protected void ReadBuffer(ModbusBaseClientStation self, IModbusMaster master, ModbusBuffer buf)
try
ushort[] registers;
byte[] adr;
bool[] inputs;
if (buf.pauseCounter == 0)
ushort startAddress = buf.startAddress;
ushort numInputs = buf.numInputs;
switch (buf.ModbusDataType)
case ModbusDataTypeEx.InputRegister:
case ModbusDataTypeEx.HoldingRegister:
if (buf.ModbusDataType == ModbusDataTypeEx.InputRegister)
registers = master.ReadInputRegisters(buf.slaveId, startAddress, numInputs);
else
registers = master.ReadHoldingRegisters(buf.slaveId, startAddress, numInputs);
DateTime dt = DateTime.Now;
int iresult = 0;
uint uresult = 0;
double fresult = 0.0;
foreach (ModbusChannelImp ch in buf.channels)
switch (ch.DeviceDataType)
case ModbusDeviceDataType.Int:
adr = BitConverter.GetBytes(registers[ch.ModbusDataAddress - buf.startAddress]);
switch (ch.ConversionType)
case ModbusConversionType.SwapBytes:
byte tmp = adr[0]; adr[0] = adr[1]; adr[1] = tmp;
iresult = BitConverter.ToInt16(adr, 0);
break;
default:
break;
if (ch.ModbusFs2InternalType == ModbusFs2InternalType.Int32)
ch.DoUpdate(iresult, dt, ChannelStatusFlags.Good);
else if (ch.ModbusFs2InternalType == ModbusFs2InternalType.Double)
ch.DoUpdate((double)(ch.K * iresult + ch.D), dt, ChannelStatusFlags.Good);
else
if (self.LoggingLevel >= ModbusLog.logWarnings)
Env.Current.Logger.LogWarning(string.Format(StringConstants.ErrConvert,
self.Name, ch.Name, ch.DeviceDataType.ToString(), ch.ModbusFs2InternalType.ToString()));
break;
case ModbusDeviceDataType.UInt:
uresult = BitConverter.ToUInt16(adr, 0);
break;
default:
break;
if (ch.ModbusFs2InternalType == ModbusFs2InternalType.UInt32)
ch.DoUpdate(uresult, dt, ChannelStatusFlags.Good);
ch.DoUpdate((double)(ch.K * uresult + ch.D), dt, ChannelStatusFlags.Good);
else
break;
case ModbusDeviceDataType.DInt:
byte[] adr0 = BitConverter.GetBytes(registers[ch.ModbusDataAddress - buf.startAddress]);
byte[] adr1 = BitConverter.GetBytes(registers[ch.ModbusDataAddress - buf.startAddress + 1]);
byte[] res = new byte[4];
res = self.SwapBytesIn(adr0, adr1, ch.ConversionType);
iresult = BitConverter.ToInt32(res, 0);
else
break;
case ModbusDeviceDataType.DUInt:
uresult = BitConverter.ToUInt32(res, 0);
else
break;
case ModbusDeviceDataType.Float:
fresult = BitConverter.ToSingle(res, 0);
ch.DoUpdate((double)(ch.K * fresult + ch.D), dt, ChannelStatusFlags.Good);
else
break;
case ModbusDeviceDataType.Bool:
bool bit = (registers[ch.ModbusDataAddress - buf.startAddress] & (0x01 << ch.BitIndex)) > 0;
if (ch.ModbusFs2InternalType == ModbusFs2InternalType.Boolean)
ch.DoUpdate(bit, dt, ChannelStatusFlags.Good);
else
break;
case ModbusDeviceDataType.String:
byte[] str = new byte[2 * ch.DeviceDataLen];
Decoder ascii = (new ASCIIEncoding()).GetDecoder();
int bytesUsed = 0;
int charsUsed = 0;
bool completed = false;
int j = 0;
// Conversion strategy: FIRST NONPRINTABLE CHARACTER (ORD < 32) BREAKS CONVERSION, string consists of printables converted before
for (int i = 0; i < ch.DeviceDataLen; i++)
byte[] word = BitConverter.GetBytes(registers[ch.ModbusDataAddress - buf.startAddress + i]);
if (ch.ConversionType == ModbusConversionType.SwapBytes)
if (word[1] < 32)
break; // nonprintable character
str[j++] = word[1];
if (word[0] < 32)
str[j++] = word[0];
else
if (word[0] < 32)
str[j++] = word[0];
if (word[1] < 32)
str[j++] = word[1];
//Array.Copy(BitConverter.GetBytes(registers[ch.ModbusDataAddress - buf.startAddress + i]), 0, str, 2 * i, 2);
string sresult;
if (j > 0)
char[] chars = new char[j];
ascii.Convert(str, 0, j, chars, 0, j, true, out bytesUsed, out charsUsed, out completed);
sresult = new String(chars);
else
sresult = "";
if (ch.ModbusFs2InternalType == ModbusFs2InternalType.String)
ch.DoUpdate(sresult, dt, ChannelStatusFlags.Good);
else
break;
break;
case ModbusDataTypeEx.Coil:
case ModbusDataTypeEx.Input:
if (buf.ModbusDataType == ModbusDataTypeEx.Coil)
inputs = master.ReadCoils(buf.slaveId, startAddress, numInputs);
else
inputs = master.ReadInputs(buf.slaveId, startAddress, numInputs);
dt = DateTime.Now;
uint val = (uint)(inputs[ch.ModbusDataAddress - buf.startAddress] ? 1 : 0);
ch.DoUpdate(val, dt, ChannelStatusFlags.Good);
else if (ch.ModbusFs2InternalType == ModbusFs2InternalType.Boolean)
bool val = inputs[ch.ModbusDataAddress - buf.startAddress];
else
break;
} // Case
if (self.failures.ContainsKey(buf.slaveId))
// failure signal defined
self.failures[buf.slaveId].Value = false;
} // If
else
buf.pauseCounter--;
} // Try
catch (Modbus.SlaveException e)
buf.pauseCounter = self.FailedCount;
self.failures[buf.slaveId].Value = true;
Env.Current.Logger.LogWarning(string.Format(StringConstants.ErrReceive,
self.Name, buf.slaveId, buf.ModbusDataType.ToString(), buf.startAddress, buf.numInputs, e.Message));
catch (TimeoutException e)
protected void WriteChannel(ModbusBaseClientStation self, IModbusMaster master, ModbusChannelImp ch)
try
ushort[] registers;
byte[] adr = new byte[4];
byte[] adr0;
byte[] adr1;
bool conv_ok = true;
ushort startAddress = ch.ModbusDataAddress;
ushort numInputs = ch.DeviceDataLen;
switch (ch.ModbusDataType)
if (ch.Type == typeof(int)) // ch.ModbusFs2InternalType == ModbusFs2InternalType.Int32)
int v = (int)ch.Value;
adr = BitConverter.GetBytes(v);
else if (ch.Type == typeof(uint)) // ch.ModbusFs2InternalType == ModbusFs2InternalType.Int32)
uint v = (uint)ch.Value;
else if (ch.Type == typeof(double)) // ch.ModbusFs2InternalType == ModbusFs2InternalType.Double)
double d = (double)ch.Value;
d = (d - ch.D) / ch.K;
if (ch.DeviceDataType == ModbusDeviceDataType.Int)
short s = (short)d;
adr = BitConverter.GetBytes(s);
else
ushort s = (ushort)d;
else
self.Name, ch.Name, ch.ModbusFs2InternalType.ToString(), ch.DeviceDataType.ToString()));
conv_ok = false;
if (conv_ok)
master.WriteSingleRegister(ch.SlaveId, ch.ModbusDataAddress, BitConverter.ToUInt16(adr, 0));
break;
if (ch.DeviceDataType == ModbusDeviceDataType.DInt)
int s = (int)d;
else if (ch.DeviceDataType == ModbusDeviceDataType.DUInt)
uint s = (uint)d;
else
//float
float s = (float)d;
else
conv_ok = false;
if (conv_ok)
SwapBytesOut(adr, out adr0, out adr1, ch.ConversionType);
registers = new ushort[] { BitConverter.ToUInt16(adr0, 0), BitConverter.ToUInt16(adr1, 0) };
master.WriteMultipleRegisters(ch.SlaveId, ch.ModbusDataAddress, registers);
break;
Env.Current.Logger.LogWarning(string.Format(StringConstants.ErrConvertImpl,
break;
break;
if (ch.Type == typeof(bool))
master.WriteSingleCoil(ch.SlaveId, ch.ModbusDataAddress, (bool)ch.Value);
else
break;
Env.Current.Logger.LogWarning(string.Format(StringConstants.ErrException,
self.Name, e.Message));
catch (OverflowException e)
catch (InvalidCastException e)
byte[] SwapBytesIn(byte[] adr0, byte[] adr1, ModbusConversionType con)
switch (con)
res[0] = adr1[1];
res[1] = adr1[0];
res[2] = adr0[1];
res[3] = adr0[0];
break;
case ModbusConversionType.SwapWords:
res[0] = adr0[0];
res[1] = adr0[1];
res[2] = adr1[0];
res[3] = adr1[1];
break;
case ModbusConversionType.SwapAll:
res[0] = adr0[1];
res[1] = adr0[0];
res[2] = adr1[1];
res[3] = adr1[0];
break;
default:
res[0] = adr1[0];
res[1] = adr1[1];
res[2] = adr0[0];
res[3] = adr0[1];
break;
return res;
void SwapBytesOut(byte[] inp, out byte[] adr0, out byte[] adr1, ModbusConversionType con)
adr0 = new byte[2];
adr1 = new byte[2];
switch (con)
adr1[1] = inp[0];
adr1[0] = inp[1];
adr0[1] = inp[2];
adr0[0] = inp[3];
break;
adr0[0] = inp[0];
adr0[1] = inp[1];
adr1[0] = inp[2];
adr1[1] = inp[3];
break;
adr0[1] = inp[0];
adr0[0] = inp[1];
adr1[1] = inp[2];
adr1[0] = inp[3];
break;
default:
adr1[0] = inp[0];
adr1[1] = inp[1];
adr0[0] = inp[2];
adr0[1] = inp[3];
break;
protected class ModbusBuffer
public ModbusDataTypeEx ModbusDataType;
public ushort startAddress;
public ushort lastAddress;
public ushort numInputs;
public List<ModbusChannelImp> channels = new List<ModbusChannelImp>();
public byte slaveId;
public int pauseCounter;
