Elektronik Devre Şemaları Arşivi
Konusu 'KontrolKalemi Çöplüğü' forumundadır ve Klavyeah tarafından 27 Ekim 2006 başlatılmıştır.
Konu Durumu:
Mesaj gönderimine kapalı.
  1. Klavyeah
    Çevrimdışı
    Klavyeah Üye
    28 Ağustos 2006
    296
    Beğenilen Mesajları:
    99
    Ödül Puanları:
    28
    AC power mosfet relay
    AC optically isolated solid state relay
    AC TO DC power supply +/- 15vdc
    AC to 12KV power supply
    AC TO +/-5V power supply
    Acoustic ultrasonic dog whistle
    Acoustic ultrasonic generator
    Acoustic ultrasonic range finder
    Acoustic ultrasonic intruder detector
    Acoustic ultrasonic sound receiver
    AM/FM/SW active antenna
    Active antenna HF/VHF/UHF
    AM broadcast band active antenna
    active 125khz bandpass filter
    active high pass filters
    active low pass filters
    active 60Hz notch filter
    adc0804lcn 8bit A/D converter
    Acquisition 1wire Barometer
    Addressable ADC
    Airflow detector
    Acquisition Laser data link
    Acquisition LCD counter
    Acquisition Lie Detector
    Aquisition Lie Detector 2
    Acquisition barometer
    Acquisition Strain-gage sensor
    Aquisition Temperature Data Logger
    Aquisition Thermostat
    Acquisition Ultrasonic Range & Image
    Acquisition Micromodem 4-to-8 channel A/D
    Acquisition water-level sensor
    Acquisition Thermometer project
    Acquisition wireless weather station
    AirFlow Circuit 1
    AirFlow Circuit 2
    AirFlow Circuit 3
    Aircraft receiver
    Aviation Band receiver
    Alarm pump motor monitor
    Alarm freezing temperature
    Alarm electric field monitor
    Alarm for power cords
    Alarm 4 digit keypad
    Alarm 5 zone
    Active IR Motion Detector
    Alarm motorcycle
    Alarm Car Radio
    Alarm Low Battery
    Alarm Car Battery
    Alarm Proximity
    Alarm Car Flasher
    Alarm Frost
    Alarm Lock with PIC
    Alarm cut Phone line
    Alarm combination lock
    Alarm Ultrasonic detection
    Amplitude Modulation 4MHz
    AM oscillator
    Active Antenna
    AM Receiver
    AM Transmitter
    AM RF AMP
    AM Broadcast Transmitters
    Amplifiers DC to 18GHz
    Amplifier high linearity 70Mhz
    Amplifier 1Watt 2.3GHz
    Amplifier 1Watt 2.45GHz
    Amplifier headphone 1.5vdc
    Amplifier ear 1.5vdc
    Amplifier PreAmp with Control
    Amplifier Audio 30W
    Amplifier Audio 1.5W 12VDC
    Amplifier Audio 10Watt
    Amplifier Audio 100Watt
    Amplifier Audio 15Watt
    Amplifier Audio 18Watt
    Amplifier Power
    Amplifier Audio 2Watt
    Amplifier Audio 20Watt
    Amplfier Audio 20Watt
    Amplifier Audio 200Watt
    Amplifier Equalizer
    Amplifier Audio 50mWatt
    Amplifier Audio 30Watt
    Amplifier Audio 300Watt
    Amplifier Audio 4Watt
    Amplifier Audio 45Watt
    Amplifier Audio 50Watt
    Amplifier 60 Watt
    Amplifier Audio 8Watt
    Amplifier 80Watt
    Amplifier 2.4Ghz
    Amplifier 900MHz
    Amplifier Quadraphonic
    Amplifier Optical 5MHz
    Amplifier AGC 150MHz
    Amplifier wideband
    Amplifier 40meter 4Mhz receiver
    Amplifier IF receiver
    Amplifier IF 7.8MHz
    Amplifier IF
    Amplifier IF
    Amplifier VHF IF
    Amplifier 100MHz AGC
    Amplifier 500Watt HF
    Amplifier 60Watt RF
    Amplifier 3MHz 30dB
    Amplifier VHF
    Amplifier 450-800MHz
    Amplifiers Log Converter
    Amplifier Log Converter
    Amplifier Log Theory
    Amplifier Low Noise for PhaseNoise
    Amplifier Low Noise
    Amplifier TDR
    Amplifier Radar
    Amplifier Radar
    Amplifier application guide
    Amplifier LM392 comparator
    Amplifier FET OpAmps
    Amplfier OpAmps Basics
    Amplifier Inverting NonInverting
    Amplifier current feedback
    Amplfier millivolt output
    Amplifier FM Transmitter
    Amplifier intercom
    Amplifier Radio
    Amplifier photo-transistor
    Amplifier photodiode receiver
    Amplifier transimpedance 1GHz
    Amplifier Transimpedance
    Amplifier AGC 40dB
    Amplifier variable gain
    Amplifier video digitizer
    Amplifier video
    Amplifier video sync
    Amplifier video line selector
    A/D serial port driven
    A/D video digitizer
    A/D Applications
    A/D Application ADC1210
    A/D microprocessor application
    A/D PC oscilloscope
    A/D using 555 timer
    A/D ADC080x
    A/D simple circuit
    Analog switch
    Analog switch
    Analog switch Audio
    Analog switch MP3
    Antenna loop
    Antenna active
    Antenna for AM,FM,SW
    Antenna for HF, VHF,UHF
    Antenna active
    Antenna AM loop
    Antenna information
    Antenna for Ham transmitters
    Antenna projects
    Antenna HF
    Antenna loopstick
    Antenna 540-1600KHz
    Antenna Q-multiplying
    Antenna AM Amplifier
    Antenna 915MHz
    Antenna Yagi uda
    Astable CMOS VCO
    Astable Multivibrator
    Astable multivibrator
    Astable flip-flop circuits
    Attenuator potentiometer
    Attenuator digital control
    Attenuatot TEE
    Audio meter
    Audio mixer
    Audio combiner
    Audio 4-input mixer
    Audio 6-input mixer
    Audio source
    Audio FET mixer
    Audio high quality mixer
    Audio voice over circuit
    Audio door phone intercom
    Audio high quality intercom
    Audio oscillator
    Audio level control
    AGC circuit
    AGC Wideband
    AGC 60dB range
    Automotive 3rd brake light
    Automotive tachometer
    Automotive alternator alarm
    http://www.schematicmag.com/htm1/freecircuits.htm
    _________________________________________________
    Bandpass filter
    Bandpass filter
    Bandpass notch filter
    Bandpass LC filters
    Bandpass Low Cost Filter
    Battery Backup
    Battery Backup
    Battery Charger Solar
    Battery charger AC
    Battery Charger Alkaline
    Battery charger 9V
    Battery charger +/-12v
    Battery charger NiCad
    Battery charger NiCd and NiMH
    Battery charger 12V
    Battery Charger NiCd
    Battery discharge monitor
    Battery charger car
    Battery charger with 12VDC
    Battery charger 12v monitor
    Battery charger constant current
    Battery charger Gel Cell 6V
    Battery charger Gel cell 12V
    Battery charger uses LM2576
    Battery charger for emergency lights
    Battery charger for motorcycles
    Battery charger using PIC
    Battery charger simple
    Battery charger with USB
    Battery charger with temperature control
    Battery charger lead acid
    Battery monitor 12V
    Battery monitor microamps
    Battery monitor 2.7-5.5V
    Battery Tester
    Barometer
    Beeper 110dB
    Beeper 120dB
    Buzzer using 555 timer
    Beeper battery low
    Buzzer
    Biomedical brain Wave machine
    Biomedical heart rate sensor
    Biomedical cardiac monitor
    Biomedical Km counter
    Biomedical ECG Amplifier
    Biomedical EKG circuit
    Biomedical Stethoscope
    Biomedical heartbeat monitor
    Biomedical hearing aid
    Bistable flip-flop
    Bug FM transmitter
    Bugging telephone line
    Bug telephone tap
    Bug detector
    Bug wireless microphone
    Bug insect zapper
    Bug insect repellant
    Bug mosquito repellant
    Cable Finder Circuit
    Camera 12volt stroboscope
    Camera adjustable strobe light
    Camera beat tracking strobe
    Camera Kodak flash unit
    Camera photo flashes
    Capacitor Behaviour at RF
    Capacitance liquid level monitor
    Capacitance meter
    Capacitance meter femto
    Capacitance change over a wide range
    Capacitive stud sensor
    Capacitive touch alarm
    Capacitive 0 to 10pf monitor
    Capacitance touch switch
    Current mains remote alert
    Carrier current transceiver filter
    Charger Universal
    Charge pump night light
    Charge pump 3.3v to 5V
    Charge pump Maxim
    Charge pump Maxim
    Charge pump low quiescent current
    Charge pump Maxim
    Charge pump Maxim
    Charge pump Apnote Maxim
    Charge pump Maxim
    Charge pump DC/DC Maxim
    Charge pump 5V to 3.3V
    Charge pump 4.5V to 12V
    Charge pump 2.6V to 5V
    Charge pump negative reference
    Charge pump positive to negative
    Charge pump +9V to -9V
    Charge pump +9 to +18V,+25V,+33V
    Charge pump delivers 50mA
    Charge pump 5V to 15V
    Chopped amplifier
    Chopping amplifier
    Clock generator 60Hz
    Clock 100MHz for computers
    Clock timer
    Counter 7 LED
    Clock synchronous
    Car Clock
    Clock divider
    Clock doubler
    Clock generator
    Clock doubler
    Clock using AT89c2051
    Clock Timebase
    Clock using PIC
    Clock programmable oscillator
    Clock speaking using PIC
    Clock VCXO
    Clock video signals
    Color organ circuit
    Color organ circuit
    Color organ light
    Colpitts oscillator 10.58MHz
    Colpitts oscillator UHF
    Colpitts for FM
    Colpitts VCO 2.15GHz
    Colpitts App Notes
    Colpitts App Notes
    Colpitts Oscillators and other types
    Colpitts App Notes
    Colpitts oscillator
    Colpitts 45MHz to 70MHz
    Colpitts VCO 119MHz
    Comparator LM392
    Comparators App Note
    Comparator Light Sensor
    Comparator voltage switch
    Computer serial port
    Computer RS232 ccable
    Computer RS-232 to MSK modem
    Computer serial port as a thermocouple
    Computer 10 Base-T solutions
    Computer 18-bit ADC using serial port
    Computer RS-232 to RS-422
    Computer nullmodem cable
    Computer dual port COM switch
    Computer RS-232 to PIC microcontroller
    Computer self detection for serial devices
    Computer switch handles RS-232 and RS-485
    Computer bidirectional RS-232 communication
    Computer circuit protects input
    Computer common RS-232 cables
    Computer parallel port
    Computer optical link for RS-232 communications
    Computer drive LIN with UART
    Computer control of relay
    Computer joystick
    Computer video digitizer
    Computer parallel port from serial port
    Computer powering devices from parallel port
    Computer USB decoding
    Computer RS-485 operation
    Computer USB notes
    Computer ISA48 I/O card
    Computer full duplex RS-232C
    Computer microprocessor projects
    Computer RS232 for PIC16F84
    Computer joystick interfaces
    Computer low power RS232C
    Computer EEprom programmer
    Computer 8-channel measurement
    Computer waveform generator
    Computer thermometer
    Computer frequency synthesizer
    Computer RS232 connections
    Constant current SCR
    Constant current amplifier
    Constant current battery charger
    Constant current load
    Contact bounce circuit
    AC to AC grounding and shielding
    Converter Ac to AC transformer for mHZ signals
    Converter AC to AC transformers
    Converter AC to AC regulators
    Converter AC to AC step-down converter
    Converter AC to DC RMS detector
    Cosine circuit
    Crystal filter
    Crystal filter
    Crystal oscillator 32.768KHz
    Crystal oscillator 40KHz
    Crystal oscillator 1KHz
    Crystal oscillator 1MHz
    Crystal oscillaotor HCMOS
    Crystal oscillator low distortion
    Crystal oscillator for 1sec Time base
    Crystal oscillators Applications ILSI
    Crystal oscillator pierce
    Crystal oscillator pierce-gate
    Crystal oscillator study
    Crystal oscillator 5-20MHz
    Crystal App note
    Current loop temperature sensor
    Current loop interface
    Current AC detector
    Current sensing instrumentation amplifier
    Current sensing using MAX4372
    Current monitor for high voltages
    http://www.schematicmag.com/htm1/freecircuits_2.htm
    Entes
    Entes
  2. Klavyeah
    Çevrimdışı
    Klavyeah Üye
    28 Ağustos 2006
    296
    99
    Ödül Puanları:
    28
    DC to AC 12volt auto inverter
    DC to AC 12VDC to 120AC
    DC to AC inverter
    DC to AC high voltage inverter
    DC to 110V inverter
    DC to DC voltage divider
    DC +9V to -9VDC
    DC 4-14V to 3.3VDC
    DC to 10Kv-30Kv converter
    Dc 20V to 5v 20watt converter
    DC Li-ion battery to 3.3v converter
    DC 6v to 12v converter
    DC 12v to 80VDC converter
    DC 0.8-5.5VDC to +5/+10/-5VDC converter
    DC 12VDC to +5/-5VDC converter
    DC 12VDC to -5VDC converter
    DC 12VDC to 180VDC converter
    DC 3VDC for relay activation
    DC 1.8VDC to 3/5VDC
    DC 2.7VDC to 5V coilless
    DC positive to negative converter
    DC 100-400VDC to +15/-15VDC
    DC 2-6VDC to negative converter
    DC 3VDC to 85VDC converter
    DC 9VDC to +12/-12VDC
    DC to DC conversion without inductors
    DC 5VDC to 3.3/12 VDC
    DC 36-57VDC to 3.3V/2A
    DC 36-72VDC to +/-135VDC
    DC 10-16VDC to -24/-5/1.5/3.3/5/12/58VDC
    DC negative 36-72VDC to -5/2.5/3.3/5/8VDC
    DC 48VDC to +5VDC/5A
    DC to DC layout guidelines
    DC 24vDC to +5 low cost
    DC 8-15VDC to 5VDC/3A
    DC 12VDC to -12VDC
    DC positive to negative converter using 555
    DC 6VDC to -9/+9/150VDC
    DC 5VDC to -5VDC
    DC 5VDC to 12/-12VDC
    DC 36-80VDC to 3.3VDC/2A
    DC 555 step down power supply
    Decibel meter
    Decibel peak-reading meters
    Delay circuit 5Min.
    Delay circuit analog
    Delay compensation for video
    Delay timer 2-3 hours
    Delay windshield wiper
    Demodulator asynchronous
    Demodulator clock recovery
    Demodulator costas loop
    Demodulator QPSK
    Demodulator BER meter
    Digital readout 7 segment
    D/A Applications multiplying
    Dimmer 120VAC
    Dimmer 230VAC
    Dimmer Lamp
    Dimmer neon
    Dimmer regular load
    Divider frequency circuits
    Doorbell circuit
    DTMF generation
    DTMF products
    Electronic lock using PIC16F84
    Electronic combination lock
    Electronic card lock system
    Electronic combination lock with AVR
    Electronic combination lock with PIC
    Electronic 5 digit alarm keypad
    Electronic lock (dongles)
    Emergency backup light
    FET buffer
    FET 25W amplifier
    FET amplifier
    FET preamp cable
    FET based gain control
    FET micro spy
    FET current sensing
    FET power amplifiers
    FET replaces switch
    FET as a temperature sensor
    Field strength meter
    Filter Chroma
    Filter High Pass 10Khz
    Fluid level detector capacitive type
    Fluid level sensor
    Fluorescent Lamp driver
    Fluorescent Lamp inverter 40W
    FM Receiver
    FM transmitter
    FM bug
    FM 3v transmitter
    FM Beacon Broadcast transmitter
    FM booster
    FM broadcast transmitter
    FM telephone bug
    FM transmitter
    FM low power transmitter
    FM long range transmitter
    FM modulators
    Frequency meter using PC
    Frequency counter using 68HC11
    FSK modulator
    Frequency synthesizer at 2GHz
    Frequency to voltage converter
    Function generator
    http://www.schematicmag.com/htm1/freecircuits_3.htm
    Hartley FM transmitter
    Hartley oscillator
    Hartley oscillator electronic canary
    Hartley oscillator
    Hartley VFO
    Hartley wildlife tag
    High frequency notch filter
    Humidity and temperature measurement
    Humidity transmitter
    Humidity signal conditioning
    Indicator 4 line telephone status
    Indicator battery monitor
    Indicator 3-level audio power
    Indicator 50MHz frequency counter
    Indicator battery charger
    Indicator rate-of-change battery charger
    Indicator blown fuse
    Indicator cut phone line
    Indicator CW tuning DTMF
    Indicator fuse monitor
    Indicator hot water tank heat
    Indicator parking aid
    Indicator phone line in use
    Indicator telephone circuits
    Indicator telephone headgear
    Indicator water level
    Indicator water level controller
    Infrared Transmitter
    Infrared Receiver
    Infrared 40KHz oscillator
    Infrared info
    Infrared receiver general
    Infrared motion detector
    Infrared cordless headphone
    Infrared receiver
    Infrared laser detector
    Infrared control tester
    Infrared transmitter
    Instruments frequency counter
    Instruments inductance meter
    Instrumentation amplifier
    Intensity Measurement
    Integrator circuit
    Integrator blocks for filter designs
    Integrator theory
    Integrator opamp
    Integrator opamp
    Intercom doorphone
    Intercom system
    Intercom system
    Jacob's Ladder
    Joystick build your own
    Joystick Port
    Joystick port
    Joystick schematic
    Joystick port as input
    Keypad DTMF coder
    keypad 4 digit
    Keypad using 1 pin
    Keypad using PIC16C54
    Keypad using PIC16C620A
    Light Bulb Regulator
    http://www.schematicmag.com/htm1/freecircuits_4.htm
  3. Klavyeah
    Çevrimdışı
    Klavyeah Üye
    28 Ağustos 2006
    296
    99
    Ödül Puanları:
    28
    Magnetic field detector
    Magnetic gun
    Magnetic levitation
    Magnetic radiation remote control
    Magnetometer
    Magnetic card lock
    Metal detector
    Metal detector
    Metal detector
    Metal detector
    Meter for stereo
    Microprocessor PIC16C508 tricks
    Microprocessor PIC16C84 LCD interface
    Microprocessor 68HC11 RDS decoder
    Microprocessor 68HC11 external clock
    Microprocessor 68HC11 stepper motor control
    Microprocessor 68HC11 synthesizes sine wave
    Microprocessor 8051 development circuit
    Microprocessor PIC notes
    Microprocessor AT89c2051/4051 downloader
    Microprocessor AT89c2051/4051 terminal connection
    Microprocessor AT89c2051/4051 7 segment display
    Microprocessor AT89c2051 night light saver
    Microprocessor AT89c2051 real time controller
    Microprocessor AT89c2051 LED driver
    Microprocessor 89c51/52/55 downloader
    Microprocessor Atmel 8051 programmer
    Microprocessor AVR AT9052313 IR detector
    Microprocessor AVR beacon keyer
    Microprocessor AVR digital voltmeter
    Microprocessor AVR frequency counter
    Microprocessor AVR motor controller
    Microprocessor AVR signal generator
    Microprocessor PIC DDS 0 to 6MHz
    Microprocessor watchdog circuit
    Microprocessor PIC16F84 combination lock
    Microprocessor PIC connecting LEDs
    Microprocessor PIC12c508 to 93AA46 Eprom
    Microprocessor AT90s2313 temperature sensor ds1820
    Microprocessor PIC electronic lock
    Microprocessor Z80
    Microprocessor PIC 16c84 FSK modulator
    Microprocessor PIC projects
    Microprocessor PIC LCD interface
    Microprocessor PIC IR remote
    Microprocessor AT90s8515 DRAM interface
    Microprocessor PIC16c508 interfacing
    Microprocessor PIC16c54 LCD interface
    Microprocessor PIC noise generator
    Microprocessor measures light intensity
    Microprocessor PIC in-circuit serial programming
    Microprocessor interface circuits
    Microprocessor PIC18/PIC16 programmer
    Microprocessor PIC 5x7 display
    Microprocessor PIC stepper motor control
    Microprocessor PIC16f84 encoder
    Microprocessor PIC demo board
    Microprocessor PIC LCD and keypad interface
    Microprocessor PIC logic probe
    Microprocessor PIC programmer
    Microprocessor PIC16f84 CW decoder
    Microprocessor PIC16F84 programmer
    Microprocessor PIC16F84 tone generator
    Microprocessor PIC tone generator
    Microprocessor PIC digital clock
    Microprocessor 68HC705c8 programmer
    Microprocessor PIC speaking clock
    Microprocessor PIC speaking doorbell
    Microwave radar detector
    Mixer SBL-1 circuit
    Modem 900MHz transceiver
    Modulator FSK
    Modulator video
    Modulator FSK
    Modulator phase discrimination
    Monostable using 555
    Monostable flip-flops
    Monostable frequency discriminator
    Mosfet 25w amplifier
    Mosfet 200w amplifier
    Mosfet power amplifiers
    Mosfet switch
    Noise generator pink
    Noise with PIC
    Noise generator
    Noise generator white noise
    Noise source
    Noise filter
    Noise filter
    Notch filter 60Hz
    Notch filter variable
    notch filter high frequency
    notch filter helical resonator
    Notch filter uses lowpass filters
    Notch filter RC type
    Opamp application guide
    Opamp building blocks
    Opamp I-to-V conversion
    Opamp current feedback
    Opamp output goes to zero
    Opamp FM transmitter
    Opamp RF oscillators
    Opamp high input impedance
    Oscilloscope 1-GHz sampling front end
    Oscilloscope 4 channel DSO
    Oscilloscope jitter
    Oscilloscope PC based
    Oscilloscope high frequency probe
    Oscilloscope NTSC sync circuit
    Oscillator 200MHz to 400MHz
    Oscillator 50 to 50KHz
    Oscillator NE602 circuit
    Oscillator simple RF
    Oscillator opamps for RF
    Oscillator RF uses current_feedback
    Oscillator RF 350MHz-500MHz
    Oscillator 1KHz sinewave
    Oscillator opamp 1MHz
    Oscillator DSP
    Oscillator analog from digital
    Oscillator generates 0 to 360 phase shifts
    Oscillator low frequencies tuned
    Oscillator opamp for RF designs
    Oscillator 10KHz to 200KHz
    Oscillator low frequency
    Oscillator App notes
    Oscillator sine wave low frequency
    Oscillator 150Hz to 150KHz
    Oscillator crystal accurate
    Oscillator sine/cosine
    Oscillator Wien bridge
    Oscillator harmonic
    Oscillator 90MHz VFO
    Oscillator VCO UHF
    Oscillator current-to-voltage
    Oscillator PIC controlled DDS
    Oscillator VCO 50Hz to 1KHz
    http://www.schematicmag.com/htm1/freecircuits_5.htm
    Pedometer
    Pedometer
    Phase detector
    Phase meter
    PLL synthesis
    PLL application notes
    PLL clock generators
    PLL LM565
    Phase-locked digital synthesizer
    PLL synthesizing oscillator
    PLL for FSK
    Phase shifting circuit
    Phase shifting using digital control
    Phase shifter
    Phase shifter
    Photo flash at 1.5v
    Photo flash charger
    Photo timer circuit
    Piezo amplifier 1KV
    Piezoelectric alarm
    Position parking aid sensors
    Position sensor
    Potentiometer cmos IC
    Potentiometer digital for difference amplifier
    Potentiometer corrects for system drift
    Potentiometer controls LCD bias
    Potentiometer converts voltage to resistance
    Potentiometer LED dimmer
    Potentiometer for programmable oscillator
    Power line detector
    Power meter
    Power meter
    Power Supply Universal
    PreAmplifier with Control
    Pressure air sensor
    Pressure sensing for water-tank
    Probe circuit RF
    Probe RF 125MHz
    Pulse width modulator
    Pulse width modulators
    Quad 303 circuit
    Quad 33 CD conversion
    Quad 33 circuit
    Quad 405 circuit
    Quad AM2 circuit
    Quadrature digital delay
    Quad 50E circuit
    Quad op amp
    Quad video amp
    Quadraphonic amplifier
    Radar detector
    Radar detector
    Radar ultrasonic detector
    Radar detector
    Radiation detector gamma-photon
    Radiation geiger counter
    Ramp Generator
    RFID receiver
    RFID circuit kit
    RFID development kit EM4095
    RFID tag reader
    Rain detector
    Rain detector
    Receiver with microvolt sensitivity
    Receiver 136.650KHz
    Receiver 30Metre
    Receiver 4.5MHz to 10MHz
    Receiver 40metre
    Receiver 40metre
    Receiver/transmitter 49MHz, 434MHz, 315-950MHz
    Receiver 50MHz
    Receiver 80metre
    Receiver 80metre
    Receiver aircraft
    Receiver induction
    Receiver FM
    Receiver AM
    Receiver AM aircraft
    Rectifier uses no diodes
    Regulated 12V supply
    Regulated bench top power supply
    RF linear 30W amplifier
    RF 500Watt amplifier
    RF 60 watt amplifier
    RF broadcast-band amplifier
    RF VHF amplifier
    RF UHF preamplifier
    RF CMOS synthesizer
    RF CMOS synthesizer
    RFID 13.56MHz
    RFID receiver
    RFID kits
    RFID kits
    RFID tag reader
    RMS measurements circuit
    RMS to DC converter
    http://www.schematicmag.com/htm1/freecircuits_6.htm
  4. Klavyeah
    Çevrimdışı
    Klavyeah Üye
    28 Ağustos 2006
    296
    99
    Ödül Puanları:
    28
    Devre şemaları Arşivi
    Safety RFI protection for line inputs
    Sawtooth waveform generator
    Sawtooth generator
    Sawtooth generator
    Sawtooth wave oscillator
    Schmitt trigger programmable
    Schmitt trigger
    Schmitt trigger has dynamic threshold
    Sensor accelerometer
    Sensor airflow
    Sensor airflow
    Sensor airflow
    Sensor airflow
    Sensor airflow
    Sensor oxygen
    Sensor for studs
    Sensor for currents
    Sensor for flames
    Sensor for flames
    Sensor gas
    Sensor gas
    Sensor gas
    Sensor TGS813 for gas
    Sensor notes on gas
    Sensor humidity
    Sensor humidity
    Sensor humidity
    Sensor humidity using FM transmitter
    Sensor light
    Sensor light direction
    Sensor light intensity
    Sensor light
    Sensor liquid for toilet tank
    Sensor fluid level
    Sensor water level
    Sensor water level
    Sensor electromagnetic field
    Sensor geomagnetic field
    Sensor magnetic levitation
    Sensor metal detector
    Sensor PIR Infrared motion
    Sensor air pressure
    Sensor water-tank pressure
    Sensor vibration
    Sensor RF detector
    Sensor surveillance detector
    Sensor gamma photon
    Signal generator variable frequency
    Signal generator using DDS
    Signal generator low cost
    Signal generator using PIC
    Signal generator video
    Switch pcb softtouch
    Telemetry FSK modulator
    Telephone 900MHz transceiver
    Telephone shared into 9 lines
    Telephone caller ID
    Telephone DTMF decoder
    Telephone caller ID
    Telephone ID decoder
    Telephone caller ID display service
    Telephone cellular calling detector
    Telephone customized ringer
    Telephone in use detector
    Telephone circuit vocalizes number
    Telephone cut line detector
    Telephone ring detection
    Telephone DSL filter
    Telephone interface
    Telephone line status
    Telephone music-on-hold
    Telephone in use circuit
    Telephone off-hook indicator
    Telephone FCC specs
    Telephone amplifier
    Telephone dialer
    Telephone circuits
    Telephone hold circuit
    Television video enhancement circuit
    Television 10GHz video link
    Television RGB video digitizer
    Television video switch
    Television accurate sync signals
    Television closed-caption decoder with PIC16F628A
    Television video on twisted-pair
    Television digital video processor
    Television VGA monitor driver
    Television generate video signals
    Television video amplifier
    Television LH0032 video amplifier
    Television LM359N video amplifier
    Television audio-video RF transmitter
    Television RY/BY/Y to NTSC composite video
    Television app notes Maxim
    Television video digitiser
    Television NTSC to VGA converter
    Television RF modulator
    Television S-video selector
    Television S-video to composite video
    Television S-video to VGScan converter
    Television sync seperator
    Television video generator
    Television video line selector
    Television video sync trigger generator
    Television video trigger circuit for oscilloscopes
    Television video pattern generator
    Television video/audio wireless transmitter
    Thermometer digital
    Thermostat electronic
    Thermostat heating system
    Temperature controller LM3911
    Temperature control circuits
    Temperature controller usind AT89CX051
    Temperature monitor
    Temperature monitor
    Temperature programmer
    Temperature regulator
    Temperature monitor
    Thermometer AD590
    Thermometer DS1620
    Thermometer digital
    Thermometer LCD
    Thermometer PC
    Thermocouple interfaces to serial port
    Thermometer digital
    Timer for Labs
    Triac circuit
    Triac dimmer
    http://www.schematicmag.com/htm1/freecircuits_7.htm
    UHF 433Mhz Transmitter
    UHF 433Mhz Receiver
    UHF VCO
    UHF remote control
    UHF 100w amplifier
    UHF oscillator
    UHF preamplifier
    UHF VCO
    Ultrasound using PIC
    Ultrasonic rangefinder
    Ultrasonic detector
    Ultrasonic generator
    Ultrasonic motion detector
    Ultrasonic parking sonar
    Ultrasonic pest repeller
    Ultrasonic radar
    Ultrasonic range & imager
    Ultrasonic range finder
    Ultrasonic circuits
    Ultrasonic switch
    Unijunction transistor
    UPS supply
    UPS for USB devices
    USB Interface Circuit
    Variable gain amplifier
    Variable gain amplifier low noise
    VHF 20dB amplifier
    VHF low-pass filter
    VHF beacon transmitter
    VHF transmitter
    VHF/FM transistor radios
    VHF/UHF TV modulator
    Video Chroma filter
    Video amplifier
    Video S-to-composite
    Video amplifier
    Video Camera Intruder Detector
    Voltage doubler
    Water level alarm
    Water level reference design
    Water level sensing circuit
    Water level sensor
    Wattmeter AC
    Wattmeter
    Waveform conversion
    Wideband AGC
    Wideband white noise generator
    http://www.schematicmag.com/htm1/freecircuits_8.htm
  5. Klavyeah
    Çevrimdışı
    Klavyeah Üye
    28 Ağustos 2006
    296
    99
    Ödül Puanları:
    28
    Simple Uhf Am Receiver
    400mhz Receiver Using Analog Device's Vga
    10khz High Pass Filter
    50 To 500khz Oscillator
    high Linearity Rf Agc Amplifier
    radio Fm Receiver
    uhf 433mhz Transmitter
    uhf 433mhz Receiver
    capacitor Behaviour At Rf Frequencies
    dc To 8ghz Simple Amplifiers
    direct-conversion Mixer Using Sbl-1-1 Dbm
    rfid 13.56mhz Receiver Circuit
    ne-602 Voltage-to-frequency Oscillator Designs
    general Circuits
    preamplifier With Tone And Bass Control
    video Camera Intruder Detector
    ramp Generator
    usb Interface For Pc
    lab Timer Using St7lite09
    chroma Filter
    pcb Softouch Switch
    30 Watt Audio Amplifier
    universal Power Supply
    s-video To Composite Converter
    led Meter For Stereo Applications
    ac Cable Detector
    telephone Amplifier
    universal Battery Charger
    ultrasound Radar Using Pic16f628
    125mhz Rf Probe For 20mhz Oscilloscopes
    light Bulb Regulator
    9 Channel Ir Transmitter Using Pic Microcontroller
    9 Channel Ir Receiver Using Pic16c55 Microcontroller
    intensity Light Measurement Meter
    http://www.schematicmag.com/htm1/monthly_folder/paid_page.htm
  6. _Galvanize_
    Çevrimdışı
    _Galvanize_ Yeni Üye
    23 Kasım 2006
    2
    0
    Ödül Puanları:
    ya arkadaşlar bana DSHT devresi lasım bu saati, hava sıcaklığını, nemi ayarladığımız zaman aralıklarında göstericek devre hangisi acaba bana kalırsa vardır arasında ama bi yardımcı olursanız şu öğrenciye çok iyi olur şimdiden danke schön
  7. batınay
    Çevrimdışı
    batınay Yeni Üye
    18 Ocak 2007
    7
    0
    Ödül Puanları:
    sn üstadlar acil olarak ph ölçer devre şemasına ihtiyacım var yardımcı olurmusunuz.
  8. can_01
    Çevrimdışı
    can_01 Yeni Üye
    24 Şubat 2008
    0
    Ödül Puanları:
    saatlerdir ups devre şeması arıyordum valla beni büyük bir dertden kurtardınız cok teşekkürler
  9. ferhat41
    Çevrimdışı
    ferhat41 Yeni Üye
    1 Ağustos 2007
    0
    Ödül Puanları:
    Dost lİnkler aÇilmiyor
  10. Burçin ERİŞEN
    Çevrimdışı
    Burçin ERİŞEN Yönetici Yönetici
    24 Eylül 2007
    755
    323
    Ödül Puanları:
    163
    Meslek:
    Elektrik & Elektronik
    Linkler çalışmadığı için KONU KİLİTLENMİŞTİR .
    Sn: KlavYeaH linkleri düzelttiği zaman konu paylaşıma açılacaktır.
: elektronik, semalari, arsivi
Konu Durumu:
Sayfayı Paylaş
